Custom Switches or Panel supplier?
Track Addict
GOLD FF Supporter
Have the Tucker apart and while I am at it I want to address the dashboard.
Another member turned me on to speedhut.com for gauges but what about switch panels with labels?
Open to ideas
Be aware most of those fully illuminated rockers will be overpowering (and irritating) at night, so only use in positions that will be limited use or critical to making sure it gets turned off.
You can get illuminated switches that the bulb circuit is separate from the switched circuit. Then either an after market dimmer, or build your own.
That is what I am looking for, but so far I have only found LED illuminated switches that would require PWM control to dim...
