IMP, The OC4 I'm working on now has a crack in the same place as yours repaired by brazing, it looks like it worked well. I have more cracks to fix. The steering shaft hole is broken out so I did few test welds with heliarc and steel filler rod and I found the case to weld like steel, not cast iron. I'll get to working on it again soon, as I'm welding this week. I'm setting up my machine for 'cold wire(feed) heliarc'. A surprising number of planetary diff parts are made of cast steel, or something so similar that makes it weldable. I welded up some cracks in a M-29 case with heliarc and steel filler rod and it was a pleasure to weld, the base metal is so clean. I welded a spool that was completely broken in half at the base of the drum bushing journal and its still going strong, actually imroved the ring gear runout in the process. Heliarc and silicone bronze rod may work too.
-Pat
