BadAttitude
Installing a 10' counter in my kitchen remod and looking for some advice for scribing to fit. Anyone have experience doing this?
Durwood said:Set it in position and put a carpenter pencil against the wall resting on the counter top and go down the wall following the contours of the wall marking the top. Then you can belt sand it if not to bad.
Dur
B_Skurka said:That would be easier for a do-it-yourselfer!
But if you do it the way my installer is doing it you can buy a whole bunch of new toys!I mean tools.
B_Skurka said:It is my understanding that the top will come in pre-cut to fit my wall. The slab is cut on some sort of a computer controlled saw at the plant before they deliver it. That is why it is so critical to get the measurements so accurate.
BadAttitude said:That's sounds like quite the technoligy Bob...but it wouldn't work for me. My CT is already made. The problem I have is how or what is the best way to conmpensate for a wave in the wall. Close to 3/16" from hi to lo over a 2-3' distance. The walls are already finished and painted and somehow this error was missed...don't ask![]()
I did scribe the line OK and have 1 1/4" backsplash to play with. But if I scribe this to fit the wave, I think it will look like crap. I imagine I could do some mud work to level it out, but was hoping there was another option.
Durwood... sighting down the 10' length, I think the wave will be obvious since the backsplash will only be an inch thick. Any suggestions?
I thought of using caulk, but I'm not sure if I can do it neatly. Biggest problem would be laying too much caulk and then trying to finger it smooth...BTDT and what a mess I madeDurwood said:You might split the difference if it isn't to bad and let a bead of silicone help fill the gap a little (just not to much). It's tough sometimes to match up existing stuff and sometimes all you can do is split the difference so it isn't one extreme either way.
Dur
LMAO!!Durwood said:One other thing is once you get everything set on the countertop it may not be that noticable. If it is take your M-I-Ls picture and hang it there and nobody will ever look that way.![]()
Dur
BadAttitude said:I thought of using caulk, but I'm not sure if I can do it neatly. Biggest problem would be laying too much caulk and then trying to finger it smooth...BTDT and what a mess I madeThanks for the tip on splitting the difference. At least I haven't belt sanded the CT yet.
I'll have to practice a little with the caulk before I try it. Maybe I can do better than I think I can.
Thanks
Kubota King said:The installers used cardboard when they installed our granite counter tops. They fit perfect.
Here I'm driving myself nuts worrying about it. I only have one chance to make this fit and I don't want to blow it. Once I start sanding, I can't put any back. As for the laser...yep, that's me LOL if you only knew what I strive for
Are you saying just caulk the gap or run a small bead the full length? I would think the full length would look better.Durwood said:One last thing. You don't have to split it exactly down the middle. I myself would try to keep the silicone small as i could when splitting it.
Dur
B_Skurka said:I presume you mean they came out and made a cardboard template, they went back and cut the scribe line to fit the wall in the shop, and then delievered and just fitted it into place? If so, that is essentially what my installers are doing, only they are using a high tech method.
I gather that "BA" is installing laminate or some other material that can be shaped on site. I gather that would explain the different processes used.
BadAttitude said:Are you saying just caulk the gap or run a small bead the full length? I would think the full length would look better.
Thanx...your making me feel that much more confident.Durwood said:Run the bead the full length. I meant instead of taking the whole 3/16 out of the backsplash take only half or a little less out than that and make the difference up with silicone. I see you have the window so that will help break up the view of just siteing down the top.(as you mentioned) Like i said before once you get everything on the countertop then i doubt you will notice it anyway. Nice job on the kitchen btw, it looks good.
EDIT= I've done worse than that before and they turned out good.
Dur
BadAttitude said:Thanx...your making me feel that much more confident.![]()
Still a little gunshy with using the caulk for finish detail work...and it seems everytime I get near the stuff, I end up wearing most of it too![]()
I never did try using a wet spoon to smooth it. I'll give it a try, maybe that's the answer I'm looking for.
