JimR
Charter Member
Yesterday I just picked up an older Warm Morning coal stove for the old farm for free. It is about 2 ffet square and about 40 inches tall. It is bricklined with hollow bricks on the 4 corners (air flow maybe). There is a large door and small damper cover on the bottom where the ash pan is. There is a lever inside there for shaking the coal ash. On top in front there is another large door with a sliding grate on it for air I would assume. I installed this stove in place of a rotted out wood stove in the boiler room. How the heck do you run these crazy things. I have no information on it and have no clue. I do have it running now. But not sure if it is right. I started it by burning a wood fire than adding a good layer of coal on top of the wood coals. Then I put about a gallon of coal on top of that once it lit. This morning the coals were burned down to the bottom and red hot. So I shook it down a bit and added more coal. I checked the fire 2 hours later and it was just about dead. I relit it using my propane torch from underneath as the stove was full of unburned coal. What am I missing here to keep this thing running? I have the lower door closed and the swinging cover closed. I have the top sliding air door half open. TIA, Jim
