Clutch for1979 bombi
drev
were can I find a Clutch for a 1979 Bombi? I believe that mine just went out.
Feels like its is going into gear but nothing moves?
if it happened all at once i would guess it lost the drive hub have you tried an adjustment.under normal wear and tear you will notice some slippage in high gear before it fails to pull. if the hub broke out it will require a replacement any ways. Brad at minnasota out doors would be my first call, he will be able to tell you an application to order for or just sell you one
I was told its a 79??? not a 100% sure, how would a guy find this out for sure? I have the serial # but the Model # is 1?
i had seen a few post's in the past i think there is something special about them. if you were going with something real strong you might look at a springless hub and custom clutch built at a clutch rebuilder.
