Change the brake bands (Bombi)
kalle
I will change the brake bands on my Bombardier Bombi, and I wonder if it
is anybody know if I must disassemble Differential to remove the lower brake band?
Is there anywhere described how to take apart Differential?
Thanks in advance.
For Brakes band disassembly of the differential is not required. The unit how ever may have to be lifted up but I don't think so. Once you have the top cover off, I am betting you can get the bands to "roll" out as they are hinged in the middle if it's like the Ski Dozer. If not you pull the axles, and then the diff.....
Hope this helps, Kirk
It went well, I got loose brake bands without touching the diff, you just have to take movable adjuster bolt to brake the bands first.
Thanks...
