The lovely Mrs_B embarked on a kitchen remodel last year, that is still in progress this year.
We now have wall tile that was custom cast by a small pottery for us in patterns that were developed by architect Frank Lloyd Wright. The tiles will be used to build a backsplash over the cooktop that I installed just after Christmas. The original plan was to then use a standard field tile above the custom tiles and tile up the walls to the ceiling. But now we have a new plan.
Or is this ANOTHER new plan?
Anyway, just above the countertop will be a narrow band of these special tiles, above that she would like cherry panels that extend up 18" above the counter top, and that will be capped off with a cherry rail. The tiles will also be used above the cooktop. All of that will be in the kitchen area.
But yes, you knew there would be more . . . she wants to transition the cherry panels into the dinette and into the hallway.
So now I need to find cherry panels and have some cherry boards milled. Here is the question, what thickness cherry panels do I need for this? I'm thinking 1/4" would be sufficient? The baseboards, vertical stiles, and chair rail all have to be milled as well since the current baseboards will have to come off. I'm thinking of using 1x boards for all of this. Each board will have to be routed to accept the panel so the panels will be held in place by the rails/stiles. There will be a vertical board every 24"
- Now here is my really big question, do I float the panels or do I use an adhesive to adhere them to the walls?
- Really big quesiton #2, anyone have any suggestions (photos) of the detail of a chair rail so I can see how to finish off the top piece?
