BROKEN TUCKER
cloud5070
just bought a 1975 tucker 1300 series at ritchie bros looking for service/ parts manuals also looking for an axle shaft as one is broken at the drive sprocket any info useful as this is my first tucker after many atvic snow master's tks grant
We used to mail out a CD that had digital copies of the manuals on them but with the advent of the internet we now have a download site where you can pick you manual and download it directly to your computer.
We have a copy of the Tucker 1300 series manual. LINK => http://www.goldcordmine.com/manuals/
If you can post pictures of your broken sprocket you may be able to get someone to 'talk you through' a repair.
Cloud-
Tuckers of that vintage use Dana axles, so you should be able to go to any good driveline/axle/transmission shop and they should be able to either fix or replace your axle shaft.
Cooks equipment, in Vermont, mite have the part you need. We replaced an axle on our 76 1542 and he had a used one. Our Tucker has a International truck Dana 60 with a 6 bolt axle flange and they are hard to find.
finally found an axle same as dodge d 100 2 wheel drive 1964 or older could use a spare any one with a dodge in their back yard ??? maybe tks grant
i have found a source for axles but was having trouble setting axle bearing preload pulled diff and found spider gears had been destroyed dodge 741 diff 4.56 ratio hope its not as hard to find as the axles
