crafttree
I have a 4t10 that has been modified and now runs with 601 tracks. I keep breaking grousers on the left side, 5 so far, while running over snow.
The track tension on the left side is tighter than the right side. The slack adjuster on the left side is backed off all the way. The track was put together by overlapping and bolting together with the grousers.
Not sure what my problem is , is it possible to break grousers because the track tension is too tight?
The curved part of the grousers does not touch the top of the wheels and it does on the right side. The track tension keeps the track suspended about 1/2 inch above the wheels on the left side. The tension is the only difference I can see in the two sides.
I do have the aligator track fasteners that join the ends of the tracks together. If I took the track apart and put on the aligator clamps, I would be able to back off the tension on the left side. If track tension is not the problem I did not want to do this.
Anyone have any ideas as to what my problem is or a solution.
