Viking
HI guys...long time no post...
Just wanted to drop in and get your thoughts on my tractor problems. I have a Cub Cadet 5234D diesel sub compact tractor 2004 model. Owned less than 2 years, 125 hours. In the 125 hours I have had the following repaired or replaced under warranty:
Original tranny repaired, still did not work...Then cub replaced entire tranny. I am on my second tranny.
3pt. hitch lift cylinder failed...replaced
Rear plastic body panel (large panel over both rear wheels) cracked due to manufacturing defect...replaced
Throttle linkage slipping...repaired
Now the tractor is back in the shop because the front axle is locked/bound up tight AND the 4wd transfer mechanism is locked up tight. This stuff broke at the same time. Dealer said that Cub wants to completely replace the front axle. They (Cub) knows there is a problem with the front axle binding up once the tractors get "some" hours on them. The dealer is going to repair the 4wd transfer mechanism.
Cub did give me an extra year of full warranty when they installed the second transmission so I have 1 more year of warranty. What is concerning is that Cub knows about the front axle problem but not telling the owners. I am just about at the end of the original 2 year warranty period and could have gotten screwed (I could have had to pay for a new front axle) if if I did not get that extra year of warranty from Cub.
Have I had enough go wrong (major problems) in such a short period of time to ask for my tractor to be replaced or bought back? Is that unreasonable? The tractor performs great when it is working but I am quite concerned about about long term dependabilty. Every major component has broken except for the engine. I am thinking about trading it or selling it once I get it back from the dealer if I can't get Cub to replace it with a 2006 model or buy it back. Any thoughts guys.....Thanks
