Broke leg
MrLiberty
I think I might have broken a steel plate that is in my right leg. The only reason I suspect that is because I have done it on four other occasions. Ever since my younger days when I did football and rodeo, I have had steel plates in both legs to hold them together. I have always had arthritis in my knees and hips, but getting old hasn't helped.
Anyway, I try and do as much walking as possible, and I try to remain active, however this past month I have been having a lot of pain in my right leg. I'm not sure how I did it but I'm pretty sure I either broke the plate or it is on the verge of breaking. Since I have done it many times in the past I know what it feels like.
My friends want me to go to the docs right away, but I want to wait until after the holidays. It would suck going to the hospital for surgery and then to rehab during this time of year. And, then I would be laid up for at least six weeks, I couldn't handle that.
Anyway, I have a high pain tolerance, but it hurts even when I'm in bed. Before I go to bed I have been taking a big shot of Jack Daniels and three extra strength Tylenol, it helps for a while. If it does get to bad I will have to go see the doc sooner. :sad:
Man. That sucks. Having been through hell the past two years I can understand. They wanted to put me under the knife in December but I told them to hold off until January.
Sent from my SM-N915W8 using Tapatalk
Ah man, I hate to hear that.
There are some things one can suffer through and put off for a while and others that you can't ... no matter what time of year it is.
You know your body better than anyone else so, if you want to delay, it's your decision to make. I'm with you as I tend to put a lot of that stuff off until I think that it's absolutely necessary with no alternative. I could have probably saved myself a lot of pain over the years if I hadn't been quite so stubborn and just given in to the obvious.
Good luck. Hope you can hold off without that causing more issues for you.
Libs, you need to be listening to PG on this one. Don't screw around. Your legs come in real handy when you need to walk.:shifty:
Bummer.
A friend of mine just had a second surgery. This time to remove screws and a plate. Was in a lot of pain after it broke loose.
Hope yours is a simple fix.
Bummer.
In the past they just went in and replaced the steel plate. I have several in both legs, they kinda hold my legs together. My body doesn't absorb calcium so my bones are weak and I have broken both legs many times over the years. I have broken many bones throughout my body over the years too. Hopefully when I see the doctor it will be just a quick fix like in the past. I may go see her on Monday as the pain is getting worse, especially in the morning, and it is getting harder to get out of the chair. :sad::sad::sad:
Don't they use titanium in you?
Titanium is stronger and lighter than steel.
http://www.azom.com/article.aspx?ArticleID=1794
That's what they used in me.
My left knee, leg and foot have been internally reconstructed with titanium rods and screws etc.
I also have kind of a rod in my left arm.
All from that traffic accident that also gave me a closed head injury (and seizures).
It was done over 13 years ago and that part of me seems to be holding up pretty well.
Here are some pics. I can joke about it now because the pain is over.
My Knee: This pic has to be my favorite. Good way to get your son to became a surgeon.
More fun than being a metal worker, better working conditions and A LOT more pay!
My Leg:
It sure was broken wasn't it?
Humerus? I didn't think it was so funny! Sorry surgery joke there.
Foot/Ankle:
Kind of looks like there are NAILS going into my heel doesn't it?
I do limp with the left leg but that is because my left leg is now 1/2 inch shorter than the right leg. I have to have a very expensive built on orthotic lift place on the left shoe.
It costs about $100. That doesn't include the price of the shoes. I need good ones. It helps them to have a good shoe, not a flimsy one to build the orthotic lift onto.
I like Rockport shoes. The last pair I bought cost $55.99.
I don't wear them around the house though. I can walk a bit without the built up shoe.
I can walk really well. I have to since I have seizures and can't drive. Cabs are pretty expensive and the bus stop is probably around a quarter mile from me.
I can't really run now but that wouldn't be good anyway since I might have a seizure and fall over while trying to do so.
I had a patient on rehab once.
She had an antibiotic cement spacer put in after hers broke because of an infection in her hip after a replacement.
This is why I am so concerned and sure hope it doesn't take the route it possibly could, Mark.
Cat, at my age if I was to try and run I can guarantee that I would have a seizure and fall over. :yum: Getting old is real bitch. :hammer::hammer::hammer:
Dayum. At least I don't have steel plates and screws holding me together. This is what I was left with after being hit by a truck at the age of 5. Broken femur that was almost a compound fracture. When the doctor reset it the skin stayed attached to the bone. It healed like that and basically the muscle reformed around the skin. It's made doing things like riding a bike a little difficult as the muscle pulls around the skin. Also have a slight limp as the right leg is a couple inches shorter now. I have the shoe lift as well. Helps to align the hips and spine.
My Leg:
Foot/Ankle:
Yep, they are titanium, and the doctor that did the last few surgery's said you are not suppose to be able to break them. I proved 'em wrong. :sad:
This sounds like something you shouldn't put off. There are times when waiting for several additional weeks can really
exacerbate an injury and make recovery both longer and harder; you don't need that.
:sad:
OK, back from the doctors visit, and I have good news and bad news
The good news is I didn't break my plate in the leg like I thought.
The bad news is I have been walking around on a fractured hip. I fell in the tub about a month and a half ago and apparently rebroke a fracture from long ago. They also told me I have no cartilage left in that hip and that I should have a hip replacement.
I have to think about that for a while.
Oh man!
Well you have to do something about it.
So sorry to hear this.
:neutral:
Wow. That's gotta hurt. Take care of it. My mother has had a hip replacement already and she's not even 60 yet. Made a world of difference. She could barely walk before. Now she is able to walk around with little to no pain.
DUDE!!!! You want to die of kidney failure!?!? NEVER EVER take alcohol with NSAID's!!! Please just take the pain killers only! :ermm:
