BR 100 detracking
Stuart
After detracking my BR 100 in my gravel driveway I completely removed the track and noticed that the rear boggie wheel is out of line with the others. Before I take it apart Im wondering if anyone else has had this problem and is there a way to adjust it or has something possibly been bent. I Know they will detrack easily on hard ground if you try and turn to sharply but I was going ahead a bit and backing up a bit to make the turn , also this is the second its has happened but the first time I didnt notice the rear boggie wheel was out of line. Thanks for any input
Hi stuart I have a bombi that I am combing through to learn and I found the Front right drive flange bent and also the right rear Wheel also bent out of line with a string stretched along the chassis/frame. I have removed the rear at the splined Axle and the twist is there in that arm. ( I assume someone backed into something) the front is going to need some love. I have a photo of the front here. http://www.forumsforums.com/3_9/showthread.php?t=49587 You can see how the alignment is off, the previous owner did not mention the tracks beigh driven off, I did not experience that either in the few hours I operated it. I just found these items during random wrenching.
