evilstevie
We've got a mid 80's Bombi that we have no headlights or dash lights on.
So far have checked all known fuses, all known ground connections, and all accessible areas of wiring harness to verify nothing out of the ordinary.
Have also replaced voltage regulator, and of course have verified both headlights do work under direct power. Have also verified that we do not have voltage out of headlight wiring, and that all dash bulbs are functional, but will not light.
Short of isolating sections of wire and verifying continuity wire by wire, is there a smart way to troubleshoot this issue? Any relays or other likely problem areas that we should check first?
All other exterior lighting, and interior dome lights, etc., do work fine.
Any ideas are appreciated!
