As an off highway equipment, portable service tech for over 30 years, I can understand the value and worth of the manuals. As for the 80-90, I find it very hard to fathom putting anything more than a GL1 in this application, and I will explain why: Eaton/roadranger makes the most popular truck transmission in the world. The range shift mechanism (lo to hi, hi to lo) utilizes an air cylinder, fork clutch collar with a synchronizer making the shift seamless and quiet. This synchronizer is nothing more than a lined friction surface (brake) that contacts a cone on the gear, so that when contact is made, the friction material grips the cone, the speed of the shaft and gear are now matched, and the shift is completed. One surefire way to destroy the function of this synchronizer is to add a lubricant with a service classification of anything higher than GL1. 80-90 is a GL4, and when subjected to the friction and wiping action of the synchronizer, the Extreme pressure additives oxidize, burn, or carbon up the friction surfaces on the synchro, eventually carboning or burning it until it either flakes off its backing, or just can't match the speeds anymore. In extreme cases, the loads from not being matched in speed shears the pins in the synchro and it slam shifts. So utilizing the 80-90 in a wet brake system subjected to that much heat, brings my little peabrain to thinking that it is only a matter of time before the oxidation on the band will limit its ability to function. Just the way I see it, so I will be draining the gear oil out (which is what I assume is in it given the odor in the cab) and refilling with chevron 1000 thf, since I have scads of it on hand. As for friction modifiers, I realize that a posi additive will make it worse, as its purpose is to take the clunk out of a posi, which is caused by a non releasing clutch pack (or brake), but somewhere over the years I saw a friction modifier for lock up torque convertors that would make them bite tighter, taking the shudder out of them. Sorry for being so windy, but there it is in a nutshell, IMHO. And, folks, this is a great forum, and the knowledge of the people helping us all out is top notch. I hope not to wear out my welcome.... everyone-- best wishes your new year turns out great.
