Bombi differential case water condensation problem
Radar4xfour
After rebuilding my differential and cleaning the entire system with great care I finally was able to use the little machine for some fun……once. I ran it for a few hours one day. A week later I was ready to run the machine for the second time. I took the time to check the differential fluid to be sure everything was fine after the rebuild. I removed the fill plug and was rewarded with frozen fluid, the same with the drain plug. I knew the condensation problem existed but I didn’t know it would be an issue after one running. If it matters after running the machine it was left outside and not brought into a heated area. Any suggestions on what to do to eliminate the problem? No Boggie, selling it or leaving it sit is not an acceptable solution!
Thanks in advance,
Radar
Thanks in advance,
Radar
drop it off @ 12377 county Road 2 :yum:
radar we have used a desiccant filter on the breather line and solves the problem contact me and we can set you up.
