Binwil lift pump problem
johnaq
Hi,
I bought a used Binwil TPO 7 lift and just finished setting it up. All the electric works, motor runs, filled with new fluid, but the pump doesn't seem to be pumping. I am thinking that it needs priming or it is shot. Does anyone know how to prime it or if it doesn't need priming how to test?It is a Nihon spindle pump PA 5LA130
Thank you for your reply. We were able to solve the problem we had, by swaping the wires. The way I wired it (3 phase) i had the pump rotating in reverse. I swapped two wires and it works.
