Not sure about you guys, but I'm always finding a need to spray some herbicides around the property. Whether it be the weeds around the mailbox, grass trying to come up in the gravel drive, keeping walking paths clear in the woods, etc.
I've got a 25 Gallon tank sprayer for the tractor that works great, but its typically overkill. Rarely do I need to spray that much.
1 and 2 gallon tank sprayers are a pain in the rear, but convenient for smaller areas like the rock gardens.
This spring I purchased a 4 gallon Backpack Sprayer from Tractor Supply. Its a ROUND UP branded sprayer. It appears to be identical to the D.B.Smith 'field king' back pack sprayer. Cost was about $79. It was one of the more expensive backpack sprayers that I looked at while shopping at the big-box stores.
I've used it nearly a half dozen times this year and have to say its one of the handiest, easy to use tools I own. Holding 4 gallons give you quite a bit of capacity so you can spray the gravel drive (or most of it) without coming back to refill a small pump sprayer several times. Fully loaded it weighs about 38 pounds and if you are lifting it up to put it on from the ground it is manageable.
If you are right handed you can set it with the pump handle on the left side, or visa versa. The spray wand is on a long enough hose to allow you to reach and easily move around, but not so long that it gets snagged. It requires minimal assembly, most of which is deciding which side you want to attach the pump arm to and then attaching it.
The shoulder straps are padded nicely and there is a waist band that is also padded. The plastic back plate is contoured and shaped to fit an adult back with nothing to poke or rub into your spine. Its comfortable to carry, even when full loaded.
I've had ZERO leaks, ZERO problems, which you should expect from something purchased this season.
If you are in need of a sprayer and have been frustrated by other options, this one seems to be a good choice. There may be better. There are cheaper. There are more expensive. I'd buy this one again.
