johnday
The Crazy Scot, #3
A few days ago, I went down to Tom's shop and picked up one of the weights he takes off forktrucks. No problem fabbing up a bracket to attach to the TPH. My idea is to fab the bracket so I can leave the weight attached to the tractor, and hookup three point stuff to that. My problem is, how do I fab up a bracket to recieve the hitch pins on the implement? The top link is no problem either, just the bottom two. A piece of 3/8 flat, with a shape cutout would reciece the pins, but how do I keep the implement from falling off once I raise the 3 point? I've measured the distance between the pins on my rake, boxblade, and back blade. They're all within an inch of each other, so I see no problem there either. I think the advantage of leaving the weight and bracket attached all the time, is that I'll be able to use it for not only a counterweight, but for ballast on the implement also, without having to screw around making a seperate mount for each piece.
What say you wizards of the welder?
