MNoutdoors RIP
one thing you might consider if you wish is to install a second alternator
and use it to produce 140 volt power DC if you put full 12 volt power to your
field conection which can be on a switch with a say 60 amp alternator you can produce 120-140 volt dc power which is great for running electric heating options it will also run most brush driven tools skill saws and drills
A 60 amp will produce 7000-9000 watts which will do a lot of heating. will run any element driven apliance. toasters, electric frying pan.
You can pull the diodes and produce AC but the cycles will very high ( depends on the number of poles in the alternator)
Do not exceed the amp rating of the alternator or you will toast the diodes.
you can use larger alternators also . but requires more hp to run
60 amp at full load can pull up to 10 hp from engine
