95 Dodge one ton Diesel Looks like oil pump failure
FrancSevin
Proudly Deplorable
Nore than 350,000 miles on the clock and it looks like oil pump failure.
Guage suddenly went down.
I was only about two quarts down. However, the gauge has been reading slightly lower than normal of late. So, I have kept an eye on it.
I got the truck home with no apparent damage. However, this is gonna cost. And I am way down on cash.
I had a Mercury Cougar that lost oil pressure, but no engine noises before I shut it down. Jacked up the engine. Pulled the pan, pulled the pump, replaced crank bearings and rod bearings with - 0.001 bearings, new pump. Oil pressure back and drive that car for a couple more years before I sold it.
As slow as it was turning, I bet the damage if any is minimal. Fred is right a set of bearings, and a new oil pump will cure
anything that might have occurred.
Not sure how hard it would be to drop the pan. Is it 2wd or 4wd? On my Mack diesels you can drop it with ease. Not sure about my 2016 6.7 Cummins. Could be the front cover is involved in either engine.
I have a 92 Ford with about the same milage and the oil pressure gauge reads low on it as well. Until you slam you fist on the dash just
above it. Just needs a little motivation lol.
We can do oil changes, battery and top of the engine stuff but,,,; Dropping the pan and doing it in my driveway is against HOA rules here.
Frankly I stopped doing major vehicle repairs years ago.
I will have it done professionally. Assuming no damage, cost should be reasonable.
Ive got an extra 24v cummins with no blow by with less than 200k on it. I imagine shipping would be cost prohibitive though.
  • Like
Reactions: Doc
I spoke with the diesel mechanic a few days ago. He told be they would do a diagnostic ($185.00) and tell me what is wrong. i told him the truck is 27years old and the diagnostic will tell him nothing.
It is either the oil pump or it is the sending unit. If he replaced the sending unit on a 400,000 mile engine, it likely will need it soon at any rate. If that doesn't solve the problem, then by elimination, it is the oil pump. So pull the pan!
Old school logic.
His response was they have a procedure from which they do not deviate.
I related the story of a shop that told me, via their diagnostic, my engine light was not because of the alternator but because the third cylinder was dead. There was a tell tale vibration on could feel. Sitting in the truck with the engine running I told him that "vibration" was typical of diesels and was the same as the day I had bought the truck brand new. I kicked him out of the cab and drove it home, replaced the alternator and "walla" the "E" light vanished.
And, the gauge on the dash now read 14 volts.
"Please" I said to this young new school mechanic, "Just fix it"
So, today I got a call from the shop that it was indeed the sending unit and my truck will be ready Monday. No charge for diagnostic. Just the new part and labor to install it.
