mbsieg
awful member
Platinum Patron
:smileywac
:eek:
Hopefully it was a gradual break so the driver had time to get the heck out of the seat .....otherwise he's trapped in that mess.
I can't imagine WHY someone would take a tractor like that out onto a dock. Any idea what he was attempting to do?
This pic may help you see it a bit better .....:thumb:
Ahhh, it's a bridge. Did you know the unlucky tractor owner? Hopefully it's not YOU. :eek:
By golly the bridge maintenance crew show be fired. I will bet that cause some paper work to be done by the operator.
That looks to be a bridge over a drainage/irrigation ditch. It's likely, then, that it is a privately owned structure and not a public right of way. Therefore, the landowner, or some such private party is responsible for maintaining it. It may have been one of those cases where, "We'll get to fixing that bridge someday." Well, I guess it's now Someday!
John Deeres have their doors to the left side of the instrument console, at the front of the cab, so the operator should have been able to open the door and step carefully (As would anyone following his footsteps:yum: ) out of the cab to safety.
They also should have had planks tire width apart running the whole length down to help distribute the load over more planks than just the planks under the tires!
