HI folks, starting a remedial maintenance project for a friend--1969 Spryte 1201B-55, S/N 1384 in South Lake Tahoe, CA.
I think it has the C4 automatic transmission, anyway he put a new trans cooler on it and it is still "spitting up" ATF on the ground, apparently overheating?!?
any ideas?
What is the proper fluid for this trans? I'm not sure about the ATF he is running now, Dexron or something. I am going to change the fluid and filter and see if that helps things.
(BTW it has the OC-12 rear end and I am going to get the Cat TO-4 oil for that)
also the rubber steering brake hose looks rough, is there anyone who stocks that part??
any ideas?
