56 Tucker 443 drive shaft u-joints
muskeg1
Can anyone give me a lead on part numbers for my u-joints. Can I still get cups with those nifty anti spin notched corners? Cups are 1.143" dia and u-joint is 3.25" wide.
Thanx
Marty
Do your U-joints have the "C"-clips on the inside of the yokes, outside of the yokes, or the 2-bolt strap across the end?
I've had all three versions between '53 and '58.....
If it's the type in the first pic, it's probably a Cleveland P96.
If it's the type in the second pic, it's probably the Spicer 5-350X.
Thank you Mountain Track and others. Mine are identical to the first pic above, the Cleveland P96 u-joint photo. Coincidentally I found that exact short shaft in my extra gear pile (my tucker came without motor and tranny) and therefore located the additional cups i needed to complete my driveshaft requirements.
There are two different u-joints on that short shaft and my drive shaft joints are the same as the smaller of the two. I am hoping the Cleveland P96 reference will lead me too that joint for future replacements.
Thanks again
Marty
