1404 Imp - Looking for LED Headlights
ViaLisboa
As the title suggest. I am looking for LED retro headlights. I had to get a replacement bulb from the local Napa and the lights just barely fit in and overall I am not totally impressed with the halogen lights so looking to go to the next step.
I don't need anything fancy, just a bright LED light that will fit in the stock housings that I am told are freightliner lights. Thanks for any pointers!
Round four-light setups normally use standard 5.75" bulbs like H5001 and H5006 which were common in cars biult before 1975. Remember LEDs don't heat up the light's face and melt snow/ice like standard halogen. If you go with a plastic-faced light with LEDs biult in, you will be scraping snow/ice off plastic but these LED headlights will likely fit without modifications. If you get a glass-faced housing with a LED bulb insert, modifications may be necessary even if the seller says otherwise. Most cars have holes in the sheet-metal buckets behind the lights so overall headlight length doesn't matter but that is not the case in many snowcats. Also, beware some LED headlights have a module on the wire between the headlight and plug that you will need to accomondate.
Sorry, I can't recommend a LED light for you. I bought glass-faced housings with 4000 lumen LED bulb inserts from Octanelighting that were longer than stock headlights. I had to use a hole saw to cut the sheet-metal light bucket's back out and epoxy grease caps over the holes on the inside to get extra room. I know that is not something you want to do.
Some aftermarket LED replacement headlights, especially less expensive ones, are flood type lights. They light everying in front of you with no cuttoffs nor hot spots which is normally great for snowcat use. When its snowing and you turn the high beams on, the high beams' upward tilt generates a lot of glare especially with flood types. My LED replacement headlights use the same flood-type headlight for both the low and high headlamps. I added an extra swith and wired my lights so all four headlight low beams can be on together - to minimize glare when more light is needed.
Thanks for the very comprehensive response. I don’t want to modify the lights but it kinda seems like I may have to.
I’ve done some searching and found these on amazon and curious if they are similar to the ones you mention and if they’ll work?
Thank you again!
Looks to be the same thing I bought - if the bulb type is "036-G5-LED (3)".
If you have the same light buckets, then you'll need to modify them. I also had to enlarge the wiring holes, install new grommets and replace the old sockets (plastic was cracking).
We put some generic 5.75" LED headlights from Amazon in ours.
They work great. The only issue was that the tab was not there for orientating them, so you have to be careful to get them horizontal.
I seem to recall we looked through the specs to find some that were shallower.
I also had to install new grommets and replace the old sockets (plastic was cracking).
I think my plastic sockets are shot too. Where were you able to find replacements?
I’m guessing the mentioned grommets are the ones for wiring behind the buckets? It’s the only ones I can think of.
I use the octane reflectors z mentions. I retro fit Hid bulbs in mine. One spot, one flood. Then i put yellows, (incadescent) on the insides.
I hate leds
Got the H4 sockets/connectors with leads from NAPA or Amazon.
The lights come with wiring harnesses that have a plug end, a socket end and a semi-fat module in the middle. I wanted the module inside the cab and didn't want to cut and solder the harness (in case I returned the lights). So I enlarged the wiring hole to fit the socket and used solid grommets (from Amazon) with a small slit in them to accommodate the wires. Afterwards I sealed the slit with a dab of silicon caulk. The other option was to cut the harness wires between the module and socket, feed the wires through the existing grommets, and solder them together as well as cut the cat's sockets and harnesses's plugs off and solder those wires together.
