57', thru 60' have an 1192 CC "36 HP" industrial. Not worthy of rebuilding.
60' Thru 65, or 66, Should have a 40 HP, Industrial also 1192 CC. This motor only produced 35 Horsepower. Also not a very good candidate for rebuilding.
For about a year there were 1300 CC motors, Industrial, that produces 50 HP. This is a very good engine and can be fitted with 1500 or 1600 Cylinders and Pistons. That should be around 67, but both AKTIC & Westerasmachiner, the 2 manufacturers of Snow Trac, tended to install the previous years engine in the machines.
After about 67 or 68 all the machines had 1600 industrials, with the exception of a few special order machines that had Porsche Industrial 1600 CC Motors that produced 60 or 75 HP. All of the VW industrials used in Snow Trac's have an Engine serial Number that starts with 116 or 126. This is not covered in John Muir's "Idiot Book". If your engine has a letter before the numbers it is a VW Car Motor, not original equipment, and CAN be identified by the Engine identification chart in the "Idiot Book". You need to go by the serial number on the block, right below the pedistal that supports the generator, which is also where you put oil in. Since the Fan Housing is removable you can't go by the tag there. If the number on the fan housing doesn't match the one on the block the engines not original.
There were 1500 CC Industrial's in some machines, but VW never Manufactured a 1400 CC engine, in Bug, Bus or Industrial.
