So I searched, and read up on the different attempts to make splines. Most recently Reddogs steering wheel adapter.
I busted out a file and said how hard can that be......
After 48 minutes of filing and sweat I wound up with this.
This is a pilot project for my personal use. I am hoping to report in mid to late next week with some data. if the run out is perfect I will consider making these by request.
They are the same tooth count as Louis' build.
Special thanks to Don for the layout parts. Thanks to kirk for taking my giggly phone calls about whether or not these will work.
- they are metric.
- the splines are indexed the same relative to the sprocket teeth.
- The seal surface is not the same RW hardness as OEM sprockets.
