Eric L
Long before I owned my Tucker I had seriously considered building my own snowcat. I'm very capable in the fabrication and mechanical areas, but limited in funding. thought some kinda automotive based rig could be affordable, capable and fun.
The fact that the older Tuckers are largely automotive based was my reason for wanting that brand, as well as bing kinda "old school".
lets discuss this...
Engines and trans should be no problem, and the cab/body could be whatever suits ones particular needs/wants. may even use an existing vehicle, i.e. Jeep or mini truck.
a two track would seem the easiest setup. but this is also the area that would require the most $ and thought. I think the tracks could be fabricated using formed heavy guage sheet metal and conveyor belting..I dont think the cost would be too crazy here. bogey axles and wheels could be common stuff too. my main concern would be the drive "axle". Tracks could be a PITA to make yourself, whats a new set of tracks cost these days? yeah I know, I could call Tucker or Camoplast and ask...
I noticed A. Parsons' Kitten looks to have a standard auto. based (Like all Tuckers) axle with "steering" brakes on it. is that a variation of the original setup? If an "open" diff is used, when the brakes are applied to one side only, the opposite side will turn something like twice as fast as normal assuming the brake is fully stopping the one side. is this how a Kitten works?
how long would the brakes last?
How about a tractor based (like a Thiokol) axle? availability? durability? weight? cost?
Drive sprockets... Need somthing common that would bolt to whatever axle is used. automotive axles can be re-machined or custom made to whatever you want, but something that bolts up to a common bolt pattern would be best. any insight to bolt patterns on common application sprockets?
I remember when the Mattracks came out I thought I wanted them and thought they'd really be the cool setup, but theyre pricey too. I'v seen some home made units like them, but have been unimpressed overall.
Eric L.
Thanks.
Eric L.
Thanks.
