I'm putting my Snow Trac up for sale.
$9000 will take it away.
Located about an hour drive southeast of Chicago in Northwest Indiana.
Sorry, I don't have a trailer so I can't cart it to you, you have to pick it up or arrange to get it transported.
It runs well, starts easily. Front drive sprockets probably need to be replaced after a couple more seasons. I literally did not use it this year. Its sitting on the car lift and and has been there since I parked it there at the end of last season. A few of the bogie tires are flat, I presume they simply need to be aired up, but I do have both spare tires and spare tubes that come with the Snow Trac as part of the sale.
Headlights died sometime over the past year, I presume the fuse blew? Worked and then all of a sudden didn't. It was the end of the season and I didn't bother to check. The front facing auxillary lights (PIAA brand) work as do the side aux lights. Strobe works. Electric heater works. Dual battery set up with marine quality battery switch installed to control batteries. Plywood floor was sprayed inside with 2 part epoxy to water proof it and then covered with carpet. The whole underside of the unit was also sprayed with 2 part epoxy to protect the floor and the steel subframe.
This is same unit that was partially restored by the British TV Show "SALVAGE SQUAD" and featured in one of their episodes climbing a mountain in Scotland. I imported it many years ago, finished the restoration, but then have used it for quite a few seasons so its in very good, but not perfect condition. Always parked/stored in a climate controlled garage.
