Another "Aktiv" Snowcat, not a Snow Trac
SweGus posted some photos in his photo gallery of another model of snowcat made by Aktiv, but it is clearly not related to the Snow Trac or Snow Master units. SweGus posted several photos but here is one that is not in his gallery.
Here is a link to his gallery. http://www.forumsforums.com/pp53/showgallery.php?cat=500&ppuser=316
Unfortunately I have no additional information about these units. Perhaps someone else knows about them?
I have now posted the users manual in two pdf-files.
http://www.forumsforums.com/pp53/data/2/Aktiv_Trac_p1-14.pdf
http://www.forumsforums.com/pp53/data/2/Aktiv_Trac_p15-26.pdf
The manual is in swedish though so I guess most of you will have trouble understanding it. Here is some basic information about the machine taken from the manual:
Length 253 cm
Width 163 cm
Height 200 cm
Ground cl. 35 cm
Wight 700-800 kg depending on equipment
Maximum load approx 400 kg
Ground pr. w driver approx 40 g/cm2
Speed 0-15 km´/h
Engine Rotax 373 liquid cooled 2-stroke
Transmission Hydrostatic. Mechanical steering gear w. reverse
Steering Mechanical steering breaks
Tracks Skega FASTRAC plastic belts in sections. Width 52 cm
Carrying wheels Sheet metal
Suspension Rubber torsion and spiral springs
I don't know much about the Aktiv Trac but if anyone wants to know something that can be found in the manual I could try to translate the specific parts.
As I can remember from sales ads the price for these machines here in Sweden is 15000-30000 SEK, which would be around 2000-4000 USD.
