79bombi
I am remodeling a rental home that has an artesian well. I have a puddle of water in the gravel near the well when I dig down a couple of inches after it has been dry for a while. I thought it might be the unconnected tap the county put in this summer but the water tested negative for chlorine. So I thought the well might be leaking then someone suggested there might be overflow from the well. Sure enough it is artesian. I dug up around the conduit coming out of the top and it is just electric.
Anyone think the artesian overflow is underground below the well surface? If so I might try to pipe it away from the house.
) and it migrates around through veins of gravel, sand, or loose clay. If you've had a lot of rain, you'll have more ground water because of runoff water soaking in. That stuff is always looking for a place to go. You've probably got a rusty conduit, which is allowing groundwater to enter the conduit pipe and rise to the surface. I'm betting that if you pulled your well, you'd find the water level in the well itself to be higher than normal.
